john63
Member Since 25 Jun 2010
Offline Last Active Apr 24 2015 10:17 AM
Kenmore Washer 110.47532600
09 September 2014 - 07:26 PM
Looking for assistance from the Whirlpool experts.
One of my customers has a Whirlpool-built Kenmore front load washer
Model: 110.47532600
Serial: HLT2221669
Original symptom: NO POWER
Replaced the Main Board (CCU)---W10525354
Washer now "wakes-up" and will *mostly* respond to input---but something is definitely not right.
The HEAVY DUTY / NORMAL-CASUAL / EXPRESS WASH / DELICATE cycles will *only* display 37 minutes
The RINSE and DRAIN SPIN cycle displays 31 minutes
The WHITEST-WHITES and the CLEAN WASHER selections will not display any number value---only this: " - - "
The PREWASH cycle modifier selector/indicator light---will not illuminate (not responding)
I have enabled the TEST MODE--- and all cycle indicator lights---and test functions were perfect.
The only time that I've encountered a similar set of symptoms---was on an LG dryer---in which the replacement Main Board software was not compatible with the original Display Board.
Any thoughts on this one?
GE Wall Oven
25 April 2014 - 04:03 PM
I have a customer with a GE Wall Oven
Model: JRP20SK1SS
Serial: GS60538Q
It's got me stumped.
The symptom is that the oven undercooks.
Even a frozen pizza will not be cooked in the allotted time required (after the oven has been Preheated)
I checked the PreHeat temperature rise with a digital temperature tester and it passed that test
Replaced the Oven Sensor---no success.
Both elements function perfectly (alternating between bake and broil during PreHeat)
I'm thinking a faulty Electronic Oven Control
What do the GE gurus think ?
JennAir Range
21 February 2014 - 12:04 AM
War Story of the Day...
A customer called with a complaint that *one* of the surface burners was not igniting (no spark)
JennAir Range/Gas
Model: JDR8895AAW
Serial: 14031292JA
Part Needed: Burner Switch Assy (5 switches in a harness) part # 12002792
Simple enough.
Cannot get the screws out of the burners (corroded)
Drilled all screws out---and now top cover can be removed.
Next problem...
Cannot replace the burner switch assy---unless two of the burner valves are removed (needed clearance to slide off 2 of the switches
Next difficulty...
Plugs for the switch harness can only be accessed from the back
Need to pull out the range (cabinetry on both sides)
Got that done---now onto the burner orifice assy...
Screws are *severely* corroded and will not "come-out"---even when MAPP gas is used until they're glowing embers...
Next on the list---gotta order 5 burner orifice assys and return in March (customer will be out of town).
Challenging to say the least...
GE Wall Oven
18 February 2014 - 05:57 PM
I've got a customer with an older GE wall that needs an Oven Thermostat.
The part is NLA (WB21X5209)
Anyone know of a universal Robertshaw (or similar) Oven Thermostat kit?
LG Refrigerator ER/IF
27 December 2013 - 10:47 PM
For anyone servicing the following LG refrigerator models---with an "ER/IF" error---with a Serial Number of 311KRxxx (November 2013) or older...
LFX25992ST
LFX31915ST/SW/SB
LFX31925ST/SW/SB
LFX31935ST
LFX31945ST
LFX31995ST
LMX30995ST
LMX31915ST/SW/SB
LMX31985ST
Replace the GrilleFan Assy (Part number: AEB73785610
This GrilleFan replaces the following
AEB73785601
AEB73785603
AEB73785605
The new GrilleFan Assy has a Heater mounted around the Ice Room Fan Motor---to eliminate frost/ice accumulation---which prevents "Ice Room" fan motor operation.
No instructions are provided with the GrilleFan kit.
On the *left side* of the freezer compartment---pull off/disconnect the yellow plug (defrost heater) and connect it into the new GF Assy heater harness.
Plug the new GF Assy heater harness---into the slot where the yellow (defrost heater) plug originally was connected to.
Install new GrilleFan Assy.
Re-install Freezer Door and food basket/drawers.
Done.
