pman626
Member Since 19 Jul 2010
Offline Last Active Aug 31 2012 02:58 AM
In Topic: subzero 532- frost on back wall normal ?
31 August 2011 - 02:43 PM
yes, authorized subzero tech. the only shop in los angeles.
He did my warranty work a decade ago.
thermometer says my fridge is cooling to 35F now. Before, it wouldn't dip below 43F.
maybe blowing out the condenser coils helped..
but there is a little powdery frost starting to form on the back wall.
will have to observe a few more days.
30 August 2011 - 05:49 PM
tech came today, and measured freon level. it was at ~8.5. He filled it back up to 10.
He topped off the freon 8 years ago.
if it's a closed system, isn't freon supposed to stay at the same level forever ?
He didn't check for leak, though he did entertain the idea.
he thinks that cleaning out whatever remaining dust in condenser coil might solve the frost/icing problem. Basically a wait & see approach.
He said, in the worst case scenario, if it were an evaporator leak, he would have to change the evaporator AND the compressor.
Anyone know why the 2 must be replaced together ?
My evaporator seems to ice up whenever it's hot outside, 100*F weather, which we had the past week. Kitchen is probably 86*F.
Tech thinks the compressor might be overheating, and not cooling efficiently as a result.
But there is nothing wrong with the compressors themselves; they are nice and quiet.
28 August 2011 - 06:18 AM
so if i'm too avoid original subzero evaporators, what evaporator should I get ?
does subzero make an updated version ?
27 August 2011 - 05:32 PM
If there's a leak, in what scenario does the evaporator need to be replaced ?
and if the evaporator needs to be replaced, I remember reading there was one type of evaporator that I need to avoid- one with inferior materials ?
27 August 2011 - 04:47 PM
Do I have a small leak?
The backwall frosted up a little more today, and the fridge temp rose to 56F, so I took the back panel off.
I heard the compressor shut off by itself today, so it's not running forever.
While I had the back panel off, the compressor turned back on.
Below is what the frost pattern looks like when the front side of the wall is frosted...
I already replaced the thermal control you see there.
What do you think needs to be fixed?
I'm gonna have a tech look at it, but just to get some 2nd opinions from you guys, what do I need to ask or look out for... in case he misses something ?
