Dave Harmony
Member Since 26 Jul 2010
Offline Last Active Jul 28 2015 11:06 AM
In Topic: Frigidaire shutting off after 10 secs. throwing error 62 model FEQ1442ES0
13 October 2014 - 11:25 AM
Well got another replacement board from core centric and that did the trick. Had to clear all codes from refurb board to get it running right but seems to be ok now. Thanks for all your help once again  :)
08 October 2014 - 09:09 AM
Checked heater to ground and found nothing, I have a new heater assembly but I may try air fluff like you mentioned to narrow it down before swapping out the heater.
In Topic: LG Tromm main board for WM2077CW
31 July 2014 - 08:42 PM
Thanks John, your information was very helpful, I ended up needing the other board and got it through my part supplier.
Awesome!
In Topic: kgrs505xss00 double gas oven top burners not working
08 March 2014 - 10:46 AM
Thanks I'll try that
In Topic: Samsung RF217ACWP refrigerator not cooling
23 August 2013 - 06:41 AM
Well, both frige and freezer are at room temp, compressor running and hot, I am unable to run in manual, I hold the 2 power freeze and power cool buttons for 8 secs., the numbers light up and then display is blank, I try pushing any other button and it does nothing, eventually reverting back to the prior settings. It seems like its a sealed system problem but the inability to get into manual mode troubles me. Any thoughts? This guy's unit is only 2 yrs. old and he has the longer warranty on the sealed system. I'm thinking of putting his old parts back in and have him call Samsung.
