rolandvz71
Member Since 09 Aug 2010
Offline Last Active May 17 2015 12:49 PM
Kenmore electric dryer model #110. 69822801
28 December 2014 - 12:07 AM
http://applianceguru...orum2/5306.html
The above link sounds just like my issue.......When I jump the T and W wires the dryer starts up when the start button is made.....I have no wiring diagram and was wondering is it okay to run like this?
Thanks ALL!
Old Skol Whirlpool LAF5500W1 washer rebuild
22 May 2014 - 12:06 PM
Correction to the tittle-----  MODEL # LFA5500W1
In the process of a rebuild, but have never worked on any thing this old....picked this up for 20 bucks and would like this as our own washer.
Tranny is leaking....Is there a rebuild kit with gears, gasket, etc......
Probably gonna need tub seal.
Again this type machine is new to me and would like to do this up right and any help would be appreciated!
How do ya remove the agitator?
Thx!
GE washer top loader
21 March 2014 - 01:29 PM
I will ediit with model # later tonight......
Just giving back to the site since it has helped me a few times....
PROBLEM: Washer will not spin and sometimes it will not agaite.
First thing I thought it was the lid switch....but it tested good...so here I go with troubleshooting
Selected small load
tub filled like it should
then it went into agaite.....
next: pump came on and emptyed the tub and kept running, but would never initate spin cycle.....hmmm???
After looking I found water on the washer floor like it has overfilled in the past.....made me look @ the tub water level tube. Found the bottom of the tube was looking plugged. Removed and tried to blow thru it-- it was plugged soild! Replaced tube and machine went thru all cycles...YES!!!
Thank you  Appliantology  for all the help in the past!
OLD Whripool Elect Dryer LAE5500Y1
09 January 2014 - 10:06 PM
Need a drawing and cycling thermostat part #'s
These old dryers look to have 2 wire CT's (not like new dryers that have 4 wires CT).....am I right or wrong?
All I saw was 2 wires coming off each CT to the left of the blower exhaust....sorry I do not have a pic of this.
Wish I DID!!
Did some research.....Looks like the CT's are rated @ 135 and 155 degrees
#6 on drawing 155 degree p/n 299620, 341199
#7 on drawing 135 degree p/n 295421, 341201
Now my question is which one on the dryer is the 135 degree and which one is the 155 degree and vise versa?
Noise during spin--Maytag SAV515DAWW washer ----- SEE VIDEO
04 December 2013 - 08:18 AM
I think its the snubber ring, but wanna get a message boards opinion.....now when I spray a food grade silcone base lube on the snubber ring the noise does go away for a few seconds, but will resurface back again which is making think its the snubber ring.
The noise only occurs during the spin cycle.
Thanks!
