arrow 1
Member Since 05 Sep 2010
Offline Last Active Apr 22 2015 08:55 AM
#292312 Maytag Refrigerator Model# MFI2067AES; Crazy Electrical Issues
Posted by arrow 1 on 30 April 2014 - 08:24 AM
Just some information on putting code in. I had the same exact model number and code 0202. could not get it to take the code. So I tried the putting the code in from right to left order and the fridge took the code and is working!! Has anyone else had this happen?
#266613 Whirlpool cabrio suspension rods wtw6600sw1
Posted by arrow 1 on 01 September 2013 - 06:37 AM
Replaced suspension rods and unit is spinning normally again. Thanks to all for help.
#266612 f24 error 110.47512602
Posted by arrow 1 on 01 September 2013 - 06:35 AM
After double checking all connections, I noticed the connector wiring that plugs into temperature sensor seemed loose where it is attached to the connector. One wire had broken inside connector, after repairing machine is back to normal operation.
#256949 LG WASHER
Posted by arrow 1 on 04 June 2013 - 06:06 AM
Yes you have to remove the control panel to check.
#256802 LG WASHER
Posted by arrow 1 on 03 June 2013 - 06:40 AM
Check the start push button contact area on control panel. It has a plastic carriage that acts as a spring when pushed. If the carriage is broken contact is not made. I have repaired a few of these. If you push the button and it does not spring back, most likely the culprit
#256799 Kitchen Aid Freestanding Ice Maker KUIS15NRTS0 is making ice slowly
Posted by arrow 1 on 03 June 2013 - 06:22 AM
I would check your water valve.  Be sure it is getting proper fresh water.
#253004 Whirlpool Duet Sport Washer
Posted by arrow 1 on 25 April 2013 - 06:32 AM
Also check the hose connecting the pressure switch to tub for a pinhole. Also be sure to use HE detergent if you get it going. I keep a roll of hose on my truck and always replace if I get the f20 code. Has fixed many of them.
http://www.repaircli...ber=WFW8300SW00
Also check the pressure switch by blowing into the hose connector end. Easier if you have piece of hose.
#251734 Suds alert! model wfw9500two1
Posted by arrow 1 on 07 April 2013 - 06:13 PM
Yes it was the mcu duh!
#249627 Suds alert! model wfw9500two1
Posted by arrow 1 on 06 March 2013 - 06:32 PM
Just an update: It was the ccu. Thanks for all the help
