sekong
Member Since 11 Sep 2010
Offline Last Active Oct 24 2013 11:28 AM
Asko W600 washer
11 September 2010 - 05:49 PM
The Patient: Asko W600 washer
Age: purchased June 2001
Previous surgeries: New main motor, 2008
Symptoms: after filling, it fails to agitate then clicks to either C or S. Sometimes it works, normally after a small dance that includes tilting the washer and letting it thump down onto the floor. Fortunately, our first names begin with C and S, so the fault points to who has to dance with the washer next.
Sometimes, it goes through a full cycle. However, it is now agitating and then mid-cycle goes to C or S.
Problems started when male member of household used too much powdered detergent and the pressure sensor line became occluded. However, problem could be age related.
Physical examination:
Fills fine. Spins fine. Pumps out water/drains fine. Pin trap, empty. Pump propeller, spins freely. Water inlet, demineralised. Line to pressure switch clear allows air to flow. When diaphragm disconnected from switch, air pressure does cause switch to click.
Please advise how I can do a differential diagnosis to figuring out whether the problem is the pressure diaphragm, pump motor, solenoid or something else... and the best way to do so and fix it without electrocuting self :shock:
Lastly, if there is a manual that is more in depth than the lousy one that we get upon purchase, that would be *swell*.
Ta muchly.
The female member of the household armed with a multimeter, screw driver, and willing to purchase parts instead of paying a plumber!
