Tuco
Member Since 13 Sep 2010
Offline Last Active Apr 11 2015 06:15 AM
In Topic: WP idle pully squick
20 February 2014 - 07:17 PM
Thanks for the help.
No cheapy half moon idlers or suupco with a little appliance turbine motor oil on the wheel axle.
In Topic: Weil-McLain oil boiler P-WTGO-4 water recirculation motor runs on
06 July 2013 - 08:03 PM
Thanks RegUS . Up loaded it. Good to see you guys.
06 July 2013 - 12:39 PM
Thanks Bobice,
 Found the aquastat and the relay for C1 and C2. Worked the relay gently with a screwdriver and sprayed the the aquastat board and relay with electrical contact cleaner(  garage is very dusty). I will watch the boiler operation for a few days. And start budgeting for a new aquastat($200-300).
Thanks again!
In Topic: Dryer Vent Cleaning
24 March 2013 - 05:56 PM
I have done a few vents with a Lint Eater and extra lines added. It works fine for its intended use.
 The Lint Eater has its limits on long vents with 90* turns or multable vent elbow turns ( Dr. Seuss style dryer vents).In that case  you would have to dissasemble the vent to clean it.
I use lint eater as a suppliment , after I see the vent run. I would not want to be a one stop vent cleaner with just a Lint Eater.
In Topic: Kenmore Range 790.94022600, Installed new terminal blocks.
30 January 2013 - 11:04 PM
Did you use the old burner? I prefer to use a new burner with a new block when I can.
