Tuco
Member Since 13 Sep 2010
Offline Last Active Apr 16 2014 07:19 PM
#247432 Kenmore Range 790.94022600, Installed new terminal blocks.
Posted by Tuco on 30 January 2013 - 11:04 PM
Did you use the old burner? I prefer to use a new burner with a new block when I can.
#236620 Thanks all !
Posted by Tuco on 21 July 2012 - 07:58 PM
With things changing around here thought I should chime in.
I wanted to say thanks for this forum. I hope you ( Samari)make a good return and enjoy the friends you make.
I am a lifetime member and feel I have received much more in return. Not only in tech help( that is worth money) but in moral support .
Many of you know I became an above average appliance tinker, and part timer looking to go full time. The support I received here was/is incredible.
Thanks all!
#233398 67 yr. old granny fixes refrigerator thanks to this website!
Posted by Tuco on 30 May 2012 - 05:58 PM
Yes'm. You are an incredible lady.
Your defrost heater is fine. The kit Santa recommends should help melt the ice collecting in the water drain hole.
#232040 GE Dishwasher Not Filling With Water
Posted by Tuco on 08 May 2012 - 11:16 PM
You need to replace the fuse in your multimeter. You were set to Ohms and touched a live 120 v wire. I have never done that. :thumbsup: Make sure you place your meter to AC volts for checking “hot “ wires. Check Ohms when no electrical power is on the appliance.
