Tuco
Member Since 13 Sep 2010
Offline Last Active Apr 11 2015 06:15 AM
WP idle pully squick
20 February 2014 - 03:10 PM
WP Dryer,LER7646 JQ0
Installed a dryer kit, rollers, belt , Supco roller idler pulley.
New Supco roller idler pulley makes a squick noise with drum full of laundry.
Old style idler pulley is the none rolling half moon friction style pulley , but makes no noise.
Do I need to install the original " half moon" style idler back into this dryer to insure noise free operation?
Weil-McLain oil boiler P-WTGO-4 water recirculation motor runs on
05 July 2013 - 06:09 PM
 The hot water recirculation motor drones on for long periods ,  before and after the boiler fires up.
This electric powered water recirculation motor is mounted on the top right corner a few inches above the boiler. It is wired to the main power off-on switch as is the Beckett oil blower.
I can't figure out why this motor runs sometimes for hours , then shuts off, to do it again later. I don't know what controls this motor.
Is this normal? or What can I check?
This boiler heats my house hot water and floor board radiators for house heat. (house thermostats currently  off for the summer)
Thanks all !
21 July 2012 - 07:58 PM
With things changing around here thought I should chime in.
I wanted to say thanks for this forum. I hope you ( Samari)make a good return and enjoy the friends you make.
I am a lifetime member and feel I have received much more in return. Not only in tech help( that is worth money) but in moral support .
Many of you know I became an above average appliance tinker, and part timer looking to go full time. The support I received here was/is incredible.
Thanks all!
WP Direct Drive Washer
20 June 2011 - 02:27 PM
Recieved a call to work on a WP DD washer with locked up drum.
The complaint is the drum is locked up and will not turn even by hand. Its also full of water, ( I'll pump or pinch hoses as needed).
I have to travel by skiff (boat). I plan on taking a good DD transmission with me for parts/replacement.
Are there any other parts that might need to bring?
I don't want to get over to this island and forget something simple I should have brought.
thanks.
Kenmore Elite 110.27042601
04 May 2011 - 06:53 PM
I just got my hands on one of these fascinating machines.
It was making a jet engine noise in spin. I tore it down, removing the inner tube. It was clean, no debris, the lint filter was even spotless. As I turned the input shaft by hand, it reminded me of the sound of a rusty Tonka Toy wheel.
The inner tub with pressed in bearing is about $250 and shipping.
Too bad, the machine was about 4 years old, and will retire to the city dump. Not very green after all even with its energy star rating.
