AccApp
Member Since 03 Jun 2006
Offline Last Active Mar 12 2014 03:40 PM
WFW8300SW02 power surge issue
30 December 2010 - 06:10 PM
Customer has two units same model, WFW8300SW02. They said the power went out, units locked in cycle, could not reset via normal means, door locked. Tried unplugging for +1 hour, no effect. Got one unit to show "F01", faulty CCU in diagnostic mode. Other unit showed "F28", serial communication error. I assumed both CCU's were faulty and replaced them with W10205839. Both units will start a cycle and lock the door, then nothing. It cannot unlock the door, won't go fully into diagnostic mode (all I can get it to do is flash all LED's) and doesn't ever try to fill with water. What is going on? Why can't they go into diagnostic mode? Did the steps to enter diagnostic mode change with the new board? Please help me out.
SCB1001KSS01
14 May 2010 - 05:59 AM
Guy at GE said it wasn't available. Let's show him!
GE SCB1001KSS01 stuck in Demo mode
14 May 2010 - 05:49 AM
It somehow got stuck in demo mode. GE was no help at all (really? GE was unhelpful, you don't believe it?). The owner's manual mentions nothing about demo mode. How do I get this back into normal operating mode? Owner has tried to cut the power to the unit for up to one week and it still reverts to demo mode.
Whirlpool gs6shexns00 ref lights not coming on
06 May 2010 - 05:29 AM
The freezer lights work, there is power coming into the ref door switch and it has continuity so the power is passing through the door switch. No power to either the upper bulb socket or the lower bulb socket. The main control board is sending power out and getting it back. I have checked the wiring diagrams but don't see any components in the circuit which could be open. The diagram shows a number of plugs in the wiring harness but I don't know where these might be located. Anyone have this trouble before?
Maytag LSE7806ACE fills but won't agitate or spin
23 December 2009 - 09:14 AM
Wouldn't do anything upon arrival, found open fuse and replaced. With good fuse it will fill to any level, any temp but will not agitate. When lid is opened fill stops so I assume the lid switch is OK but I could be wrong (wouldn't be the first time). I checked all the timer contacts and they seem fine. I get no power to the motor. Is it the lid switch? What else could it be?
