yukong
Member Since 27 Sep 2010
Offline Last Active Mar 17 2013 09:23 AM
In Topic: Whirlpool Cabrio WTW5640XW0 washer lock light flashing at rinse/spin
09 March 2013 - 02:07 PM
Yes I need a service manual.  Is this most likely a sensor or something more mechanical?  I am a shade tree mechanic and weekend home repair guy.  As well as some light appliance repair.  I haven't accessed the bottom of the unit, but since everything works at times or can be overridden, I am hoping it is just a sensor or something easy to replace.
Thanks
In Topic: Kenmore Elite Calypso Dryer Problem
16 October 2010 - 08:26 PM
Also, when in test mode, all the lights were displayed.  And there was an "SE" in the timer window.
G
16 October 2010 - 08:24 PM
OK.  I got it into test mode.  I was trying to set it when in a dry mode.  I tried it with it all shut down and it worked.  The code that was displayed was "SE".  I put a wet paper towel against the sensor bars and they beeped and the display flashed.  So they are fine I suppose.
So, is it the thermister?
Is that difficult to replace?
Thanks
Gary
16 October 2010 - 08:08 PM
Well, I can't seem to get it to go into test mode.  I did as you instructed and when I open the door it doesn't do anything.  Is there some setting that I need to adjust before hitting the more/less time button sequence?
16 October 2010 - 07:11 PM
The model number is 110.64082201.
The washer was the u-joint and most likely the levelor.
