mmoore5553
Member Since 02 Oct 2010
Offline Last Active Apr 15 2015 09:23 AM
In Topic: 253.57389601 side by side fridge not dispensing water
13 April 2015 - 03:22 PM
Thank you everyone for your help. I have now fixed it. I first went to bottom of quick connector under the front kick panel. I disconnected that and hit the water button and water sprayed on the floor. BONUS . It is at least making it there so the problem had to be in the door and above. I used hair dryer and that did not work. I used a ear and ulcer builb syringe and that did not work. I then heat the metal up again . I then used weed eater cord on where the cup hits the dispensor . I put it up in the nozzle to make sure not clogged there. Then i decided it was not there and had to be in the long door run.
I do not recommend this but it worked for me. Since i run wire and do electric work. I thought hmmmmmm I could put 14 gauge wire in the tube and feed it all the way up. Just like a clog in a toilet . So i fished the wire up the door and it stopped. I knew it was something blocking as I measure the distance and knew the cord was not all the way up the door. I then just worked it up and down and then i heard some noise. I then hooked everything back up and bam. I had water . I am not sure if calcium build up from a filter never getting changed or just frozen ice.
Nothing worked for me until i did it with the 14 gauge wire from the bottom of the fridge quick connection all the way up the door.
I am happy it is working and I double checked for leaks.
Hope this helps someone else.
12 April 2015 - 01:16 AM
Is there a quick disconnect under fridge I can unplug and see if water comes out to see where it is stopped up or if stopped up.
11 April 2015 - 10:38 PM
if I am not getting water on the floor where do i proceed next ? Do you have some steps I should go through.
In Topic: Water Heater Drain Valve stuck
31 March 2013 - 05:29 PM
Do they have heating elements?
31 March 2013 - 02:59 PM
His is a gas water heater. So does that change anything
