mmoore5553
Member Since 02 Oct 2010
Offline Last Active Mar 31 2013 09:20 PM
#250641 LG washer showing LE error
Posted by mmoore5553 on 22 March 2013 - 11:54 AM
just wanted to post back and thank everyone. It was the hall sensor. The burner smell went away after we replaced that sensor. I checked it with an ohm meter and it was reading infinity on one of the pins.
Just wa
#248224 GE refrigerator not dispensing ice
Posted by mmoore5553 on 10 February 2013 - 07:47 PM
Look like this is solved as there are tons of ice cubes now and they are not freezing together anymore. So i assume the valve was leaking. There is a small pinhole and the icecile is less than an inch. It is bearable now and no ice is freezing. The tempature is  -10F so that is all correct. Thanks everyone for helping and it has gone a whole day no issues as before it would only go an hr or two at the most.
#222481 Jenn Air JER8885QAS range - right-front stove top burner not working
Posted by mmoore5553 on 01 February 2012 - 03:28 PM
Okay i fixed it by just holding the clock button in again.
