kingsx
Member Since 03 Apr 2005
Offline Last Active Sep 30 2011 08:51 AM
In Topic: Gaggenau EB 378-610
06 January 2011 - 10:12 PM
how cheap?
The clock/brain may not be available if you need one.
In Topic: To replace or not Whirl GU2700 Dishwasher
06 January 2011 - 10:09 PM
you should never have bubbles.
Check connection to sink or disposal,
see if your draining the sink into your dishwasher.
The drain hose needs to go up high from tailpiece under sink.
In Topic: Emergency and begging.
24 November 2010 - 11:31 PM
Start by turning off beaker for 15 minutes and see if it will have the good sense to reset itself.
Other wise you're swimming upstream... I have little encounters with Bosch ovens.
hope you can use it for tomorrow.
In Topic: Kenmore 15 washer goes BANG at end of cycle, keeps spinning, washer moves two...
08 September 2009 - 05:29 AM
remove the inner drum and look at the drive block.
It should be securely mated to the spin tube.
In Topic: AAAAARGH!!! CUSTOMERS PLEASE DONT DO THIS!!!
08 August 2009 - 03:32 PM
Maybe they're not using enough Drano?
