eveready service
Member Since 08 Nov 2010
Offline Last Active Apr 05 2015 05:34 PM
In Topic: Speed Queen Comm. SWE26F
21 November 2013 - 08:59 PM
Take the bottom panel off & start the machine & quickly hit the motor. You can spend an hour with the meter & schematic & will come to the same place. Once you disturb the brushes it will work for a couple of loads.
20 November 2013 - 11:16 PM
Tap the motor pretty hard on left side after hitting the start button before the failure code comes on, If it starts the brushes are worn and you need a motor. There is a kit to repl. the brushes but it doesn't hold up very well.
In Topic: Gas coils for gas dryers
11 May 2013 - 08:03 AM
0603  means march of 06
In Topic: wp cabrio wtw6600sw
14 January 2013 - 08:43 PM
Thanks
In Topic: Speed Queen LTSA7AWN
12 December 2012 - 08:26 PM
not needed, use a flat tip screwdriver under the tab on the bottom of tray. remove retainer wire from seal with spring in slot on panel edge,  screws from panel bottom,swing out carefully, unclip harness from panel top, rotate panel clockwise and set off to left side, now remove clamp from tub, older models will need to remove hose from valve on rear of soap tray, newer models have a worm clamp near the seal and don't come with the long hose, seal has a tab to locate in the 12 o'clock position (wetting the seal ) on tub and panel side will help with re-assy.
