eveready service
Member Since 08 Nov 2010
Offline Last Active Apr 05 2015 05:34 PM
Kitchen aid KUDS30IXWH1
25 March 2015 - 08:36 PM
I have a KA DW for a relative which I replaced a bad door seal on. It is leaking from under the door in the corners now. The lower spray arm is not cracked but is kind of floppy (like about 3/8 to 1/2" of up & down movement) at the tip of the arm. Could that be my problem or am I on the wrong track.
orbital trans almost locked up
17 November 2013 - 05:58 PM
Anyone have any experience repairing maytag orbital transmissions. Is it worth while ? I have 2 one is leaking from the lower seal and 1 is too tight , almost locks up. Normally I just repl. them but it seems like a good idea to start repairing them. I've seen quite a few go bad this last year.
Noisy whirlpool washer WTW4850XQO
11 May 2013 - 07:57 AM
HI GUYS   Customers WP washer makes a grinding noise as its going into spin for a few seconds. It does wash and complete the cycle. I work on mostly commercial and older domestic. I've been avoiding these newer machines but it's time for me jump in. Can I get a little help from my enlightened associates?
wp cabrio wtw6600sw
14 January 2013 - 08:19 PM
Hi
The cust. called me and said washer is dead and gave him an error code of f50 &f51. Do you guys have a list of error codes on these washers? I'm not familiar with these machines , But I guess I'm gonna have to jump in sooner or later.
Bosch BIDW Shu6805UC/U12
15 August 2012 - 09:40 PM
HI GUYS,
I don't work on these units but this is a favor for a good friend. The complaint is that the machine get stuck in the cycle for a couple of hours just washing. Also the wife claims poor results and water spots on all and especially the dishes in the top rack. Claims she runs water in sink first and wash/ drain action seems just fine. Also said not much of a problem on the quick wash. Might this be the board solder connection I have heard in the forums? I looked at the board and saw a large solder connection that looked slightly very slightly scorched. Any help would be appreciated as I'm in the hot seat on this one . Other servicers have been out in the past and told them it was O.K. no prob. found and the extended warr. is over. Also I would like to get the manual for this model.
Thanks
