Mr.Dan
Member Since 09 Nov 2010
Offline Last Active Jun 22 2015 09:23 AM
#319659 Whirlpool SxS refrigerator GC3SHEXNT04 how do I get to the dispensor motor?
Posted by Mr.Dan on 11 May 2015 - 07:34 AM
Just a follow up.  Yes, the access was in the door liner  (2 sections down) not sure how I missed it before.  The shaft was rusted and badly rounded off.  Melted the ice out of the cavity, packed it with some clear silicone lube and put in the new drive shaft.  With the new door flapper assy. this shouldn't happen again.  Thanks for the help!
#318696 Thermador PRG366US Igniter/gas flow issue
Posted by Mr.Dan on 27 April 2015 - 02:52 PM
I just worked on one of these.  If the other XLO burner works try switching the POTs.  If the problem moves from one burner to the other then yes, you will have to replace the kit.  Be sure to verify that with your serial number as some of the newer units have been upgraded.
