Mr.Dan
Member Since 09 Nov 2010
Offline Last Active May 21 2015 11:05 AM
Whirlpool SxS refrigerator GC3SHEXNT04 how do I get to the dispensor motor?
27 April 2015 - 04:06 PM
Hey All,
How do I get at the in door dispensor motor on this model?  There are no screws on the inside of the door liner,  Do I have to remove everything through the front panel?  Motor runs but the drive shaft wont turn.  motor  is Part number: W10271509
, drive shaft is Part number: 2188916
Thanks
GE hydrowave washer GTWN4250D0WS mode shifter replacement
05 March 2015 - 09:29 AM
Hello All,
Does anyone have a time estimate for replacing the agitator shaft/mode shifter for this unit?  Part number is Part number: WH38X10019
.  I have the manual which lists the steps, but having not done this before i'm not sure how long it should take.
TX
Kenmore VMW 110.28002011 drive pulley stripped - how to remove drive nut
23 September 2014 - 05:33 PM
I looked at a Kenmore VMW with the splutch assy.  The drive pully is stripped out and spins freely on the shaft.  Does anyone have any suggestions on how to hold or lock the shaft to get the drive nut off?  When I turn it the shaft turns with it.
Thanks
Dacor ERDE36 dual fuel range control board replacement
04 September 2014 - 08:25 AM
Does any one have experience or instructions on how to remove the gas top to gain access to the control board on a Dacor ERDE36SCH/LP range.  I have seen all the info on testing the board, but none on how to get at it.
Thanks
GE Triton Dishwasher GSD6900J01BB constant tone after power failure
20 August 2014 - 07:45 PM
Hey folks, I have a GE Triton GSD6900J01BB that has a constant tone after a power failure.  The key pad is un-responsive.  The only way to stop it is to kill the power.  I tried disconecting the ribbon wire from the touch pad, but that doesn't stop the tone.  I figured the board had failed so I replaced that but, on power up the same problem.  Whom ever worked on this beast before me didn't replace the tech sheet so I am SOL on that front.  Anyone have any suggestions?  I am wondering if it could be the board with the LCD display somehow tied to the timer on the board?  The door switch tests fine also.
