isappliance
Member Since 10 Nov 2010
Offline Last Active Yesterday, 02:30 PM
Maytag Front Load Mod #: MHWE201YW
20 June 2014 - 01:20 PM
This machine is throwing out an F3 E2 error code which according to the tech sheet is a water temperature error. We have replaced the water sensor and the CCU as well, it worked fine for the test cycle and almost a full cycle for the customer before stopping near the end with the same error code. Now that error code comes back on right away even after a reset and will not start any cycles, does anyone have any idea on what else could be causing this issue as we have not run into it before. Thanks for the help. :thanks:
Bosch Vision 500 Washer, WFVC5400UC
21 January 2014 - 01:02 PM
Good morning guys, I have the thrill of working on a new Bosch design. Of course I can not find the manual for this thing anywhere and the problem my customer is stating that it is showing SUDS error and leaves their clothes wet at the end of the cycle. This seems to be a common complaint for people that own this machine with no fix found and I can not do any further diagnosis without getting into the tests modes. They do use the correct amount of soap and from what the customer says, the right load level. Since they haven't had a problem with it for over 3 years of owning it, I do believe them. Does anyone have a manual for this thing or any recommendations on what it can be?
21 January 2014 - 10:23 AM
Whirlpool Duet Sport Going Crazy
21 October 2013 - 01:35 PM
Got a weird problem with this machine that I can not seem to figure out and was looking for some fellow experts to chime in on this nightmare machine.
Its a WFW8400TW02 and the original problem was that the washer would shut off after a few seconds of turning on, completely blank screen and no error codes. Ran the diagnostics and found nothing, I can hear a relay click on the CCU every time right before it shuts off until it blew so we ordered and replaced the board. The new board started it right up and it ran a test cycle without problems along with 3 more for the customer until the exact same problem appeared and blew the same relay. We have checked all the wires to make sure they were properly grounded and found no loose wires anywhere, does anyone have any solutions they can think of? :banghead:
Kitchenaid Slide in Oven KESC307HBS6 Please
08 October 2013 - 10:40 AM
Need a service manual for KESC307HBS6. Any help would be appreciated.
