TheIslandTinker
Member Since 06 Dec 2010
Offline Last Active May 31 2015 11:46 AM
In Topic: DCS RGS-364GDSS-L range one burner sparking continuously
27 January 2012 - 01:43 PM
OK, I will certainly try that. I assume that what I would be looking for is if the sparking problem moves to the other burner, there is something wrong with the spark module?
I could see the arc moving across from the ignitor to the burner. It passes right thru the flame, and connects to the burner ring. I don't understand why the flame is not cancelling the spark.
Unfortunately I will not be able to revisit the customer for a week--I am only servicing that area once a week--so I would really like to have a plan for what to look for. The customer and I are getting a bit tired of each other! Any more hints you can think of would be much appreciated.
Tink
26 January 2012 - 03:56 PM
I swiped it with steel wool and inspected the ceramic for cracks. Can you suggest a better cleaning method? Thanks Reg!
In Topic: GE range CS980SN1SS removing control panel
08 December 2011 - 05:51 PM
Thanks Kurt! That did the trick. Greetings from the PNW to my favorite state east of the Mississippi!
Tink :tinkerbell:
In Topic: Tip for thawing out freezer drain
25 July 2011 - 10:57 AM
That Quickmelt is classy!
But mine is free :D
Tink
