TheIslandTinker
Member Since 06 Dec 2010
Offline Last Active Jun 17 2012 05:33 PM
Whirlpool gas range SF395LEE service manual please
29 February 2012 - 09:53 AM
Thanks!
Tink :tinkerbell:
Miele washer W1926 service manual please
01 February 2012 - 01:33 PM
Here's hoping!
Thanks,
Tink :tinkerbell:
DCS RGS-364GDSS-L range one burner sparking continuously
26 January 2012 - 03:39 PM
DCS--does that stand for Dammned Cantankerous Stove?
The owner called complaining that when ANY of the 4 burners was used, there was a constant sparking. After reading this very helpful post:
http://appliantology...0burner%20spark
I ordered and installed a replacement spark module. Partial joy--now three burners work normally and only one has the constant sparking. I have disassembled and cleaned that burner at least three times. Still tick tick tick. Does anyone have any other suggestions?
Thanks oh wise ones!
Tink
:tinkerbell:
Fisher Paykel GWL10US error code 131 rotor position sensor
09 December 2011 - 03:09 PM
G'day oh knowledgeable ones,
I have run into the RPS error code and know that I need to check out the rotor position sensor wiring and the sensor itself. My questions are:
1. Does the whole machine need to be disassembled (basked out, tub out, invert tub, etc) or can I get access by just tipping up the machine to go at it from underneath?
2. Does the rotor have to be removed to get access to the RPS, or can it be removed with the rotor in place?
3. The FP_GWL03US Service states the following on page 57:
13. Unscrew the rotor by using a 5/8 “ (16mm) socket.
Lift the rotor clear, and place in a plastic bag.
What is it that I am unscrewing with the 5/8" socket exactly? The plastic-appearing "nut" at the center of the rotor? And do I just hold the rotor still by hand while I am doing this?
This is the first Fisher-Paykel that I have worked on, so please be gentle....
Thanks,
Tink :tinkerbell:
GE range CS980SN1SS removing control panel
05 December 2011 - 01:13 PM
Oh great masters, can you clue me in on how to remove the freakin control panel from this unit? I removed approx. 10 screws underneath the control panel, and I have pulled up and out to the point I know I am about to bend some of that pretty stainless steel. No budge. It is loose along the bottom, but there is something holding it at the top that I can't see. I thought it might just be greasy crud, but I cleaned out the crack between the panel and the cooktop with a putty knife, and still no budge.
Thanks a million,
Tink :tinkerbell:
