Strathy
Member Since 11 Dec 2010
Offline Last Active Today, 11:24 AM
In Topic: Whirlpool Washer WTW7340XWO
10 April 2015 - 03:03 PM
Maker sure there is nothing stuck between the tubs ... and that you can move the inner basket up and down easily on the center shaft.  Anything creating drag on the basket can throw this error.
In Topic: Kitchenaid Kssc48qms01 thawing overnight
10 April 2015 - 02:45 PM
Here is what the flashing LED means on the inverter:
http://appliantology...nverter-boards/
In Topic: Frigidaire Washer GLTF2940ES3 E47 Error
31 March 2015 - 04:24 PM
'Twas the door switch assembly.  Job done = customer happy.  Me = happy.  Bank account = that much closer to a black number.  lol.  Thanks ApplianceMAN97.
In Topic: Whirlpool Washer GHW9250MQ0
29 March 2015 - 08:09 PM
Most likely pump issue ... clean the crap out of the pin trap on the pump and see how it goes.
In Topic: Electrolux Dishwasher EIDW6105GS1
28 March 2015 - 01:11 PM
This one turned out to be the control as well.  I checked for voltage going to the drain valve from the control and found 0 volts.  Checked continuity on the 4 wires in the harness = all good.  Then just for fun, I plugged in the new drain valve I had without installing it ... Err 11.  Same as before.  So control is the only thing left.  PITA to service though having to pull it out and lay it on its back AND still have power connected!  I ended up having to use a patch cord to power it as this install was a nightmare!
I think the difference on this Err 11 over other times I've seen it is that this one happens right at the start of the cycle - when the board is going through its checks.  It never powers up anything else - it just sits there for about 10 seconds and then flashes up Err 11.  There are a few relay clicks from the board, but nothing powers up.
