Sonic
Member Since 27 Dec 2010
Offline Last Active Dec 21 2014 09:38 PM
In Topic: Maytag dryer YMEDB850WQ0
20 December 2014 - 01:17 PM
I did a search and found someone indicating that it may be a harness problem.  They didn't say which harness or if replacing it solved the problem.
In Topic: KitchenAid range YKGSC308LS0 Thermostat/limiter
16 May 2014 - 09:18 AM
14 May 2014 - 08:10 AM
N.C. its in series with the oven elements
13 May 2014 - 09:13 AM
The part you suggest is the one I ordered first. I checked it with my meter and it is open. It should be N.C. . Maybe I was sent a bad part?
In Topic: Moffat MCCH6110HWW Front Load
09 February 2014 - 09:02 PM
Thanks! I did try that site earlier in the day and it didn't work but now it does, Thanks
