Wingerman
Member Since 01 Jan 2011
Offline Last Active Today, 06:25 PM
In Topic: GE PSS26SGRB SS, fridge left open accidentally overnight, burning smell in...
24 May 2015 - 08:35 PM
To begin with 1) Check the board for burns.  2) The compressor, relay, and overload need to be checked, as they got a heck of a workout.  3) Fans running non-stop to keep up could have taken out the motor(s) and board, hence the smell.
In Topic: Temperature Control Replacement GE Chest Freezer FCM7SUFWW
05 May 2015 - 10:12 PM
lithium grease contains mineral oil which breaks down rubber, vinyl, and synthetically produced tubing. It is preferred for use when there is metal on metal contact. Super Lube is silicone based. Lithium grease can lead to degenerated cap tube protectors in the long run.
05 May 2015 - 09:11 PM
Have always had good luck with Super Lube grease
In Topic: maytag dryer MDE960AYW BELT Problem
03 May 2015 - 10:45 AM
Another issue that may be relevant is that motor bearings, when hot, will seize and take the belt out. At first, the motor appears to run well, but as the bearing heats, it momentarily locks, breaking the belt. By the time it cools down and you change the belt, the shaft is back to normal and appears to turn freely. Just something to consider.
In Topic: mdc2257hes, Maytag sxs fridge. HELP!
09 April 2015 - 08:30 PM
Have you checked the wiring harness between fan and board? Check for continuity using wire color?
