DanInKansas
Member Since 12 Jan 2011
Offline Last Active Jan 23 2015 06:55 PM
#311593 KM (WP) small laundry center 110.88732796 sitting to one side
Posted by DanInKansas on 20 January 2015 - 05:44 PM
This is a repair I've done more than once.  I'm assuming you're good with getting the top panels off.
1)  When you go back out with the parts, get your inspection mirror and look at where the strut hits the tub frame back in the back where the light is hard to see.  These struts can wear out the tub frame and wear a hole in the frame, and you won't necessarily see it.  If you do see a hole worn in that, I would decline the repair as not cost effective.
2)  Unclip the drain pump and the motor's wire harness.
3)  There are two bolts holding the base to the frame on your left and right hand side.  These can be rusted into place, remove with care.
4)  Unclip the drain hose from the clips at the back of the frame.
5)  Unclip the water valve fill hose from the top of the tub.
This should now give you room to slide the washer assembly out where you can look at it.
The nuts holding the struts on will be really stubborn; you may need your rubber mallet as well as your wrench.  Undo the 2 5/16" screws on each side of the bolt and you'll have room to work.
Work on one strut at a time.
The strut unscrews, but it can also be really stubborn.  Last time I had to get a vicegrip on the base of the strut before I could get it into motion.
If you jumper the lid switch you can test all of this before completely reassembling.
If this is the first time you've changed those struts allow about 90-105 minutes.  Might not take that long.
#311375 Thermador DW won't drain DWHD630GCM/60
Posted by DanInKansas on 17 January 2015 - 02:32 PM
No drain BSH dishwashers:
1)  Is the filter screen at the bottom clean?  One BSH trainer told me he cleans his once a week.  I know exactly none of my customers are cleaning theirs that often. One of the most common slow drain/no drain problems is hard water/detergent build up on the screens.
2)  If the filters at the bottom are clean and passing water easily, then take those out.  Is the little cover still over the drain pump?  If it's not the drain pump just cavitates the water.  If it is still there, get a torx screw driver and an 11" cable tie.  Take the cover off, and plunge the cable tie behind the drain pump (towards the rear wall of the unit.)  Fun stuff should bubble up.
3)  While you're on your knees open the cabinet and make sure the dishwasher's drain hose is, at some point, higher than the point it drains to.
These three things fix the vast majority of my no drain BSH dishwasher problems.  If all these are taken care of then we can start looking at more exotic ideas.
#307948 Maytage PAV3240AWW washer -- sub in valve?
Posted by DanInKansas on 20 November 2014 - 08:36 PM
The solenoids point in different directions. The 285805 points the wire connectors straight towards the tub. The correct valve points them up and down.the 285805 then it could crush the wire connectors or solenoids.
Boom, done.  Not doing it.
Part of my resistance is that I really don't want to encourage the other guys at work in this habit.
#307650 GS6NBEXRB01 - Wpool SxS refer with mystery frost
Posted by DanInKansas on 15 November 2014 - 06:51 PM
Arigato Jay!
#307510 GS6NBEXRB01 - Wpool SxS refer with mystery frost
Posted by DanInKansas on 12 November 2014 - 10:15 PM
Have not checked freezer temps.  Did clean a big bunch of dog hair off the condenser coil on my first visit because it seemed like the mullion strip was hot.
On this model, you have, going from bottom to top:  the evaporator cover, the plastic liner guard that guides air up to the baffle, and the duct that feeds air to the icemaker and to the baffle on the fresh food side.
The first picture is of that top air duct, which is part #4 on this drawing:  http://www.searspart...Mod=GS6NBEXRB01
#306025 110.82822102 dryer -- eats boards?
Posted by DanInKansas on 20 October 2014 - 05:09 PM
Went out today on this.  Customer had sent the control board back to corelogic as defective.  We put the new one on, and I checked the receptacle before plugging it in.  Receptacle was not aluminum.  I switched L1 and L2 around.  At that point the guy said, "oh yeah, I have a UPS downstairs on the L1 for this."  So I plugged it in, put it underway, and watched.  Worked great for ten minutes, at which point I called it good.  We'll see if it becomes a call back, but I think this was a noisy power issue.
#305883 Walking out
Posted by DanInKansas on 18 October 2014 - 08:36 AM
Our install crews should probably do this, except that they'd successfully document about 800 cases of cross threading the inlet hose onto the water valve.
#305845 1930 to 1950? GE monogram Model RT-7
Posted by DanInKansas on 17 October 2014 - 05:47 PM
I learned this lesson the hard way.  These things make great bookcases, planters, repurposed pantries, something like that.  I wouldn't it if I were you.
#305595 Wolf RT364G rangetop gas odor
Posted by DanInKansas on 14 October 2014 - 07:39 AM
Ha! Samurai and I posted almost the same thing.  I must be getting smarter.
#305522 Bosch SHX56C05UC/46 not cleaning, cycles wrong, runs with door open
Posted by DanInKansas on 12 October 2014 - 06:44 PM
The description of the pump impeller movement is normal.
What's abnormal is the unit running with the door open. The door switch should prevent that from happening. Under the kick plate by the drain pump you should have a schematic, If you trace that you might get a sense of how the motor is still getting power.  The door switch may have been stuck in the closed position, or there may be another way the circuit is completing.
#305434 Whirlpool Dishwasher GU1500XTLS1 - Grease spots inside
Posted by DanInKansas on 11 October 2014 - 04:55 PM
So the one thing about the drain line theory that I will ask you is that this is a dishwasher with the drain line hooked up to a disposal.
It has been an excellent dishwasher for a family of 4 up until about 6 months ago when it started giving this problem.
Would I have seen something earlier if it was a drain line that was the suspect.
I really appreciate all of the input and help I have gotten from you folks.
Thanks!
Would you have seen something?  Maybe, maybe not.  Problems can develop slowly over time and something you don't notice this week can get really noticeable four weeks from now.
What I would say is that it is worth the effort to open the door and check to make sure that the dishwasher drain hose is higher at some point in its run than the place it drains to.  Poor drain hose routing is by far the most common cause I see of problems in wash quality, poor drain/no drain, extended cycle times, guckus covering the optical water indicator and probably a few other things I'm not thinking of off the top of my head.
Poor detergent use, especially overdosing on detergent, is another very common cause of problems in dishwashers.
#305257 KFIS27XCBL3 -- IM optics
Posted by DanInKansas on 09 October 2014 - 07:18 PM
Yes to the test and seated portions of the show.  I'm not sure how you'd bypass the optics in this model; this is not our old friend 4389102.  This is Part number: W10273549
Edited to add: I replaced a number of these under warranty when they first came out.  However, I was wet behind the ears then.  The receiver now subs to a different part number, which in something this young always makes me raise an eyebrow.
#305244 KFIS27XCBL3 -- IM optics
Posted by DanInKansas on 09 October 2014 - 05:55 PM
Had a call on this for "no ice."
IM was full of ice, but had not dispensed.
Put the machine into diagnostics, board reported the ice maker was "full or not present" with the bin in the door and no ice in the bin.
I took the bin out, put it back in and redid the test, the screen read "bill not full and present".  Took unit out of diagnostic and it dumped and filled.
Today received a "no ice" call.
Is there any reason not to replace the optics?  Anyone run into something obscure on this like frost over the optics, bad main boards, or something on those lines?
#305235 Should Appliances be plugged into GFI outlets?
Posted by DanInKansas on 09 October 2014 - 05:10 PM
Went out the the other day on a call where the remodelers had put the gas stove, the dishwasher and the kitchen counter GFCI all on the same circuit.
I already knew the answer to this question but didn't want to get into "well my electrician said..."
So I called Whirlpool Techline, put the guy on speaker phone with the customer in the room, told him what I saw and he said, "absolutely do not have these appliances on the same circuit and absolutely do not put either one on a GFCI circuit."
For what it's worth Whirlpool/Maytag will explicitly tell you to keep the dishwasher off the GFCI.
#305223 Whrilpool French Door WRF989SDAF Dual Evaportors
Posted by DanInKansas on 09 October 2014 - 02:45 PM
Hey, on the units you were out on with the sealing problem -- were those in the same serial # run as the problem evaporators or were those outside that run?  I ask because our Wpool regional sales rep is promising us that the problems are fixed on these units and that they now have a "normal warranty claim history."  (Boss has told him he's no longer putting dual evaps on the floor until the problems are worked out.)
