unclewigging
Member Since 17 Jan 2011
Offline Last Active Feb 12 2015 10:43 PM
In Topic: Roper Waher RAS6233KQQ Full of Water Wont Drain
11 February 2015 - 10:21 PM
Eurkea! thanks to your help, i got it working. there was a baby's sock in the impeller of the pump and had jammed it up. whats weird is how did a sock get in there and whats more, my kids are 6 and 8 and this was a sock during their infancy. wow. anyway, pulled it with some needle nose, put it back together and it all works fine again
i really, really appreciate your help. thanks
11 February 2015 - 04:41 PM
OK- I can get it to agitate and do everything but drain.  Where would I check for an obstruction?  disconnect the hose into the pump?
11 February 2015 - 04:35 PM
OK, I removed the cabinet, unlcipped the pump and now the controls work.  I can get it spin and fill but not drain.
I will check on the agitate but it keeps trying to fill water and the basket is about full.  I'll cut off the water and see....
In Topic: GE Washer WCSR4170G1WW poor was quality
30 August 2014 - 11:42 AM
Yep, green. I'll look that up.... Thanks
Oooh lovely a recall. I will verify the numbers and then guess I should call the GE consumer hot line?
Wonder if they would pay to have it replaced or best i can hope for is for free parts?
30 August 2014 - 11:12 AM
Is this about the same level of repair as replacing the transmission? I saw a video on that, I need to take the whole thing apart? .....I ain't scared just wondering if its worth it, in the long run. Thoughts.
Thanks again Eric
