ChadMcC
Member Since 23 Jan 2011
Offline Last Active Feb 03 2011 02:25 PM
In Topic: Jenn-air Dishwasher door vent
02 February 2011 - 08:41 PM
JDB-8910AWD
Thanks
In Topic: JDB8910AWS Jenn-Air Dishwash door Leaking
24 January 2011 - 12:28 PM
How would I check it properly ? Remove it ? Look inside ?
Thanks so much.
24 January 2011 - 12:13 PM
It leaks right after it fills up, when the jets are squirting. It leaked just a tad before repairs, but now the jets are much stronger.
Not sure how that vent could even become clogged. I will check it.
THANKS
24 January 2011 - 11:52 AM
Oh Great Master -
I actually laid it on its side when I installed the motor. I will check level and square too. Should I plan on the soap dispenser seal too. When I looked under it last night it looked like it was dripping out of the foam, which I think means its leaking from inside the door ?
