serv.man
Member Since 24 Jan 2011
Offline Last Active Jun 14 2013 10:23 AM
Kenmore Mod.36275211101 No gas to oven
06 June 2013 - 01:50 PM
Checked ignitorit was pulling 3.4a so replaced oven safty valve. Still no gas the gas line comes right from the regulator. Top burrners working fine. Is it possiable to get gas to burrners and not to oven safty valve. HERB
ge washer mod wjsr4160100
09 May 2013 - 03:16 PM
replaceing belt. The belt barly fits the large pully not alone reaching around motor pully. There is a belt install tool but cant see how that is going to help.Motor is 2.5 inches away from washer pully.Has anyone replaced belt without tool.HERB
Whirlpool washer Mod. wtw6400sw3
30 April 2013 - 06:25 AM
THEIR IS LOUD NOISE WHEN IT GOES INTO SPIN,ALSO LEAKS WHEN IT SPNS. DURING WASH CYCLE IT HAS NO PROBLEMS. HERB
frigidaire washer MOD. FAFW4011LWO
21 January 2013 - 08:45 AM
MOTOR NOT TURNING. HOW TO TROUBLESHOOT TO DESIDE IF CONTROL BOARD OR MOTOR CONTROL BOARD WHITCH IS BAD. CONTROL BOARD SEEMS TO BE WORKING, BUT NO MOTOR TURN.  HERB
Mod. TFX24VRSAWH NEED TO REPLACE IN ICE & WATER DISPENSER
28 December 2012 - 11:55 AM
Not sure how to remove front cover to replace the module and solnoid inside. HERB
