eZAK
Member Since 28 Jun 2006
Offline Last Active Feb 06 2015 06:04 PM
In Topic: GE Washer
06 February 2015 - 06:05 PM
Thanks everyone for the replies. I'll try to investigate this further.
Job is for a relative, about 45 min. away.
The last time I was there I checked the suspension rods. They look fine, no broken parts or excessive ware marks.
I had the front off, full load, regular cycle. Flash light aimed at center hub.
I saw no play, wobble, or any out of ordenary movement.
The owner, however, insist it sounds like a train running through her basement.
She even held the phone up, and it did sound louder than when I was there.
The Saga continues.
Q; Is there a way to run the machine in agitation mode with the lid open?
I'm thinking it is a magnetic switch.
In Topic: GE Washer
04 February 2015 - 04:55 PM
I was over there again and could fine anything out of the ordinary.
What is involved in replacing the tub hub?
In Topic: Kenmore Washer Leaking
16 January 2015 - 05:45 PM
To follow up,
The part arrived in just a few days.
Exact replacement!
Quick and easy! 5 min. tops!
Thanks again!
In Topic: GE Washer
16 January 2015 - 05:42 PM
OK, I'll be going there tomorrow.
Here is what I know so far.
The washer works as far as washing clothes.
Only when the agitator works is there a loud noise.
The basket spins fine but there seems to be a lot of play when stopped.
And I did level the machine last time I was there.
11 January 2015 - 10:22 AM
Well I found the leak!
It is in the hose that comes out of the dispenser going to the tub.
On the tub side, were a rib conects to a rib support.
I put some rubber adhesive on the area until the new part gets here.
Thanks Everyone!
