pebble
Member Since 26 Feb 2011
Offline Last Active Apr 03 2015 06:24 AM
In Topic: Bosch Wall Oven HBL8450UC/07 Clock speed
13 April 2012 - 06:44 PM
Ok -- chock this up to 'try before more troubleshooting'. Just "for grins" I went to the breaker panel and turned the oven breaker off, waited a couple minutes, and then turned it back on. Well, now it's back to keeping the time exactly correctly. The speed-up factor (10m in 6m real) kinda implies it might have had something to do with US 60Hz vs Euro 50Hz, but it would seem odd to not be using an internal crystal clock oscillator to base the time on. Regardless - it be fixed...
In Topic: Asko T760 Buttons won't respond
27 February 2011 - 11:19 AM
So... I leave it sit all open overnight and then this morning - seeing the parts laying in the laundry room - decide to check it again 'just for grins'. Well, buttons responded fine so I reassembled the dryer and it still responds appropriately. But I didn't really change anything so it more seems like either a trace that is intermittent or some component on the edge of failing. Has anyone seen these symptoms? Is this purely isolated to the display/control board? Thoughts?
thanks,
--pebble
