pebble
Member Since 26 Feb 2011
Offline Last Active Apr 03 2015 06:24 AM
Bosch Wall Oven HBL8450UC/07 Clock speed
05 April 2012 - 09:46 PM
Yes, we got a typical short power hit the other day - just enough to make all the AC powered clocks to reset. But the timer function in the wall oven (Bosch HBL8450UC/07) now runs almost double speed (clicks off 10 minutes of timer in 6 real minutes) and affects the clock and timer functions. Is there a repair manual or schematic for the oven? I checked Repair Clinic and they don't appear to have the control board, so where can I get that? Any help would be appreciated.
Thanks,
--joe
Asko T760 Buttons won't respond
26 February 2011 - 07:04 PM
Greetings,
The dryer (Asko T760) worked earlier today and then quit responding to buttons (other than power) so I took it apart and was looking for the cause - didn't see anything obvious. Cleaned the back of the dispaly/button boards with some circuit cleaner as it looked like there was a little bit of corrision build up. I put it back together enough to test and it worked - so I put it the rest of the way together and put it back in its place. And then the buttons wouldn't respond again. So, I took it out and back apart and just don't see what's causing this - unless I just have a failure in the display/button board. But I'm open to suggestions here.
Thoughts?
thanks.
