dfg1118
Member Since 28 Feb 2011
Offline Last Active Nov 25 2014 10:35 AM
HOTPOINT HTR15ABMFRWW Refrigerator freezing food
12 January 2013 - 06:59 PM
Freezer on top. The freezer is running at -10 to -30 below and the refrigerator is freezing the food.  Turned the control from 7 to 5 temp climbed to 30 in the freezer then bumped back up to 6 then goes back to -30.  I'm thinking I need to replace the temperature control thermostat or do you think it may be the defrost timer?
dfg1118
ET1MHKXMD07 Whirlpool Refrigerator
05 January 2013 - 01:09 PM
The ice cubes made in the ice maker are turning into one block of ice.  Ice cream is melting.  Refrigerator section running fine unless you turn up the temp control then refrrigerator starts to freeze beverages.  I'm leaning towards the "Defrost Timer" being the culprit? or could it be the Temp Control?  Coils are not blocked up with frost, fans are running OK.  I cleaned the coils on the bottom of the refrigerator.
dfg1118
