chipw
Member Since 01 Mar 2011
Offline Last Active Mar 03 2011 09:58 AM
In Topic: Frigidaire FEE368CCSD Range display blanks out
03 March 2011 - 01:04 AM
As long as u engage the oven it goes blank and comes back in about 10 sec.. u can repeat as often as you like in this mode. and yes.. all the top burner work good and correctly....
02 March 2011 - 11:10 PM
Sorry for the confusion.. The whole dispaly goes blank.. then about 10 sec later it comes back up. time is correct.. timer does count down. The display goes blank with in milli seconds of putting the oven in use...
02 March 2011 - 10:19 PM
I am told the stove top works fine even thou the oven display goes blank. The clock stay on and the timer also works.
And you are correct, it is a FEF368CCSD
Thanks for the responses
