35YEARREPAIRTECH
Member Since 16 Mar 2011
Offline Last Active Aug 19 2015 08:14 AM
In Topic: Maytag A612- Not agitating
22 March 2011 - 09:50 PM
check the water level switch contacts, or the wiring from it to the timer.
In Topic: Whirlpool WED8300 Dryer Shuts Off During the Cycle
22 March 2011 - 09:17 PM
An electrician can check the current while in the heating mode to make sure the circuit isn't overloaded. Also check the wiring at the breaker to see if it is hot. Dryers today are are pulling 28-29 amps with voltages of 240-245. This causes older breakers to over heat and trip. Also if the wires at the breaker loosen the will cause heat and trip the breaker.
