Dr. Buzz
Member Since 18 Mar 2011
Offline Last Active Mar 21 2011 05:05 PM
E Pluribus Unum -- Miele G858 Inlet/Drain Light
19 March 2011 - 01:51 AM
We have a Miele Incognito G858 dishwasher. Since about two days ago, the dishwasher will fill with water (although it seems to take 10-20 aliquots), and then stop. The Inlet/Drain light blinks. After we shut the machine off, and start it again, the water drains. I have made sure that the three-stage filter in the floor of the unit is clean, as well as the non-return valve. The air gap is not plugged (visually, as well as evidenced by the draining of the unit). I saw on-line that there is an overflow reservoir that has a float in contact. I took off the toe kick and face plate, but do not see water in the bottom of that portion (in fact, it is dry as a bone). Any ideas where I should go from here?
