006
Member Since 25 Mar 2011
Offline Last Active Apr 16 2011 04:38 PM
In Topic: Kenmore Heavy Duty 80 Series Spin wobble - 110.92480200
10 April 2011 - 11:34 PM
I forgot to say that I've double checked to make sure it's level.
I do hear water slosh whenever the brake is applied. If that is normal then good cause I was worried about that as well.
I will film it with clothes in as soon as I can get it back in the laundry room. I had a dryer problem which has turned into an "hey lets renovate the laundry room while the dryer is pulled out". Cause it's such a pain to get the machines in/out. Because it is so tight in there this machine is pretty much up against our hot water heater so I'm concerned about vibration damaging it as well.
Sounds like I'm being paranoid then, however,it seems much worse in person than on video lol.
Thanks
10 April 2011 - 05:55 PM
Here is the video.
-Jeff
http://www.youtube.com/watch?v=YbxKXnuE5dU&feature=youtu.be&hd=1
In Topic: Kenmore 110.96374200 Dryer has a bad timer?
08 April 2011 - 02:52 AM
Success! Put in a new timer and it works as good as new. Thanks for helping give me the confidence to tackle it regUS, the replacement of it was easy.
Also i've must have been tired when I first posted, I meant to say Kenmore 70 series within the body of the post but accidentally said 40. I didn't see a way to edit. Hopefully this helps somebody in the future.
-Jeff
