Ahh-Cool
Member Since 27 Mar 2011
Offline Last Active Apr 22 2015 11:24 AM
In Topic: kenmore refrigerator 795.79783.900
08 April 2015 - 07:32 AM
I did reset the code.
I took the back wall off and was not frozen but the fan motor on the l/h side is wobbly. (if that's a word)
So I will replace the motor.
Thanks for all the help
Stefan
07 April 2015 - 05:47 AM
ASSUMING? Cmon. You know how important error codes are for diagnosing.
Yes, I do. There is a language problem. The problem is me and the customer do not speak the same language.
So if that was your initial error, did you defrost the evap fan?? You did not mention it. Did you unclog the drain tube?
Several things can occur with LG's... water pooling fue to a clogged drain can be sucked up to and frozen around the fan... leading to a fan error.
If problem persists after clearing drain , there is a bulletin advising of fan motors coming on prior to the completion of post defrost dwell time. The remedy is to replace fan and board. I have been successful replacing fan motor only....
I really did not do anything. I found the door did not close unless you pushed it some more. The box was a little bit warm, so I figured it was a door issue.
Is there any way to adjust the door so it closes better
06 April 2015 - 08:43 PM
They were getting the code again? You mean THE code? okayyyy..... let me confer with those that can provide aid based on the information provided
patience ... I'm sure contact will be made...eventually...
I'm assuming they meant ER 1F
In Topic: electrolux dishwasher FDB4315LFCO
20 February 2015 - 01:36 PM
I found that sometimes the rubber feet like off a cutting board false off, I found one that would block off water flow sometimes and sometime not. I thought for sure it was the pump cause I could blow through the drain tub, hooked everything back up and same thing. One time I found a popcorn kernel that did same thing.
So do you think the blockage would be in the drain hose or the pump itself?
In Topic: frigadaire fphs2687kf1 door opens
25 January 2015 - 09:02 AM
Thanks, I will let them know
