swenson
Member Since 07 Apr 2011
Offline Last Active Dec 25 2013 12:59 PM
In Topic: Maytag, washer,MVWB700Vq0
24 August 2011 - 10:48 AM
no cold water only hot valve appears to be opening sometimes what would cause the lights both soil and wash to not light do they not light when there is a error?
In Topic: LG washer
23 August 2011 - 12:32 PM
It did not fail I take it the best time to check water freq is right when it displays the error code? How long do you wait until the water freq. test is done?
In Topic: GE,gas range, JGSP30GER3
19 August 2011 - 03:53 PM
its off by alot 350 set temp thermometer reads 250 when oven is set to 400 deg thermometer reads 400 deg.
In Topic: LG washer
19 August 2011 - 02:48 PM
yes i did check freq ,water level below the metal part of tumbler was not near the door and compared to other lg's ive worked on looked a normal level for water. It seems to happen just when in to the rinse cycle or just before the rinse cycle. I ran the washer in cold first no fe error then hot fe error as soon as it stopped filling i shut off washer.
In Topic: LG washer
17 August 2011 - 08:47 PM
yup 2 motors the one on the left is getting stuck and is on when trying to drain and is on when unit is tumbling
