swenson
Member Since 07 Apr 2011
Offline Last Active Dec 25 2013 12:59 PM
DDE8200GALWH Clothes are not drying in one cycle
24 December 2013 - 05:20 PM
The vent is clear what was done replaced the heater box shroud seal on bottom rear  of dryer and  safety limit cause the safety limit blew and at the time I checked heater element continuity it was good dryer was at that time not hot enough been using it like that till now.  The heater element is on the rt side floor of the dryer both cycle thermostat and thermostat have continuity 2 of them located directly under the lint screen they are the originals. I Have to run the dyer more then once and this is on cottons high heat setting automatic drying cycle on timer.  What should the drum tempature be with wet clothes and or just dry clothes in it? thank you in advance
GE,washer, WBSE3120B2CC
23 August 2011 - 12:15 PM
I put it in feild service mode 5 th led is on when in position 2 error is flood What does this need?
Maytag, washer,MVWB700Vq0
23 August 2011 - 12:11 PM
Complaint is it has a LF error code and the soil light and wash light were not lit I looked at the washer and those lights are working now what should be replaced on this. How do you change out the water valve on a maytag bravos quiet series?
LG ,dishwasher,LDS5811st
19 August 2011 - 03:22 PM
E1 error code is displayed after dishwasher trys to fill it stops at 2000 on meter it ohm' d to 1236 at 200k got a reading of 000 can we rule out the water inlet valve ? I did take apart the water inlet valve and cleaned it out thoroughly. What else can cause this ?
GE,gas range, JGSP30GER3
17 August 2011 - 02:07 PM
complaint is tempature is way offoven heats just does not stay at what the tempature is set too what can cause this?
