asteysn2
Member Since 21 Mar 2005
Offline Last Active Apr 21 2015 08:28 PM
In Topic: DCS range - RGS-485GDSS
21 September 2014 - 01:13 PM
You probably have a very small path to ground somewhere inside the oven therminostat.
But personally I'd start by taking out all those damn GFI outlets
Bob
coastalppliances.com
In Topic: Fisher Paykel DD603i-controller failure?
19 August 2013 - 10:26 PM
I suspect your controller is faulty. As for the dispenser, each soap cup has a small hole that water drains through. Use a toothpic to clear them open.
In Topic: Fisher & Paykel WA37T26G Washer - No Power
22 September 2012 - 10:23 PM
All the gwl 11 and 15 units are now coming with a 2.5 amp loblo fuse in the drain pump circuit, which protects the board if the pump goes south. Not sure if the 37's are like that as well.
In Topic: Fisher Paykel no wanna do rinse mode
22 September 2012 - 09:28 PM
I agree. Bad drain pump
In Topic: Thermador Range PG484GGEBS/04 Burner knob too tight
13 June 2012 - 09:34 PM
Really would love if you can elaborate on the process of removing the front panel and the bull nose. This is a problem Ive been trying to see around for some time now and advice would mean I can now change gas valves and potentiometers when the next job arises.
Something about the side panels coming off to access the front panel screws?
