jmm
Member Since 10 Jul 2006
Offline Last Active Yesterday, 10:39 AM
Kenmore dryer 110.62802101
Yesterday, 09:59 AM
The felt drum seal is starting to disintegrate - is there any harm in running it like that?
Kenmore 110.24862300 washer - doesnt start
18 March 2015 - 04:20 PM
I just got home and threw my gym stuff in the washer - it filled just fine but doesnt do anything more. The outlet has electricity and I depressed the lid switch manually and it seemed to click as normal. Anyplace in particular I should start for diagnostics? Its full of water now too making it harder to deal with - how to empty it? Thanks,.
Kenmore 110.62802101 dryer
06 January 2015 - 09:36 PM
Just went to get some clothes out of the dryer after theyve been in for a while and theyre still wet. Started the dryer again and gave it 5 minutes - opened the door and its stone cold. The drum is tumbling and the interior light orks. Where to start diagnosis? Thanks!
Kenmore 106.52532101 Fridge - squeaky noises
04 January 2014 - 12:41 PM
My fridge is working well but has started to make an odd noise occasionally - kind of a hum for 10 sec or so and then a squeaky noise. It seems to be coming from the freezer compartment. Any ideas - impending doom? Wait it out until something really breaks? Thanks....
kenmore 106.52532101 not cooling
18 October 2013 - 09:03 AM
I'm following the flow diagram and both compartments are warm (fridge was 50 and freezer was 39), condensor fan is running, condensor is clean, compressor is not running. How do I tell if there is voltage at the start relay? Its tucked in tight and I have to cut a zip tie to get it out - which leads to check and what should they read? I havde the parts diagram and cant find the cold control and muthaboard - other names? I feel like I'm getting in over my head....
