MAYBERRY
Member Since 25 Apr 2011
Offline Last Active May 02 2015 03:03 PM
Maytag Range M#mgr5751bds
29 September 2012 - 06:47 AM
maytag gas range,burner flames light up fine but flames go from high to low....also customer says she hears a poofing sound sometimes when baking......gas valve?
Bottom mount fridge drain problems
21 May 2012 - 01:45 PM
GE Profile refrigerator M# PDS18SBMALBS .Having a reaccurring problem with the drain freezing up causing the fan to jam up in the ice.First time got customer to let box defrost with doors open for 2 days.I took it all apart and ran hot water and tubing down the drain.Water ran down drain quickly so i figured it to be repaired.About a month later" RECALL."Any suggestions?
Frigidaire laundry center M#gleh1642fs0
19 May 2012 - 09:25 AM
washer dead nothing happening,only door lock switch stays on .any suggestions?
M#gleh1642fs0
Crosley M# crte181aw3 refrigerator leaking water inside ref section
30 January 2012 - 05:38 PM
I cleared drain top and bottom.Still leaking,think maybe styrofoam need changing?
whirlpool dryer M# LE7680XSW2
27 October 2011 - 01:00 PM
TIMER RUNS BACKWARDS ?
