puglvr
Member Since 30 Apr 2011
Offline Last Active Nov 30 2014 10:29 PM
Samsung RFG297AAWP exterior door ice/water disp disassembly
05 May 2013 - 05:05 PM
Does anyone know how to take the door dispenser apart so that I can do a repair job on the rust that is on the lip?  Since it doesn't have a frame, I didn't want to pry too hard at the unit floor until I knew.  Do I  have to remove the entire door assembly from the inside?  Bad enough a new frig with rust, but I'd like to make sure that if the rust continues under the lip that I can get to it to repair all of the rust.  The wonderful quality of today's new appliances. . . . Attached File  rust.jpg   17.27KB   23 downloadsAttached File  DSC02630edit.jpg   22.08KB   27 downloads
Bosch dishwasher SHU 9902 specific service manual
03 January 2012 - 01:08 PM
I can find the instructions to other Bosch dishwasher models, but nothing on specific to the secret moves needed to remove the outer door panel on the SHU 9900 series which has the controls on the top edge, not on a front panel. Many, many thanks for any help
Samsung RFG297AAWP?XAA
01 May 2011 - 02:16 AM
Like so many others, I am fighting the battle of the Samsung ice maker demon and getting weary.public/style_emoticons/default/boxedin.gif Apparently there is no access for the repair or service manuals for this model, as noted in the manual request forum. Does anyone have access to the particular key combination pressed to begin self diagnosis mode or option mode? For earlier models you press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible tone. That doesn't appear to work with this model. Any help or ideas appreciated!
