roberto
Member Since 04 May 2011
Offline Last Active Aug 10 2015 09:47 AM
In Topic: Kitchen Aid Refrigerator KSSP48QHS00
13 March 2015 - 04:20 PM
Issue resolved. Turns out that the cover was apparently removed and replaced small sheet of white plastic that was glued to the back of the liner. Thanks
13 March 2015 - 09:43 AM
Thanks again. We have the part. We have the parts illustration showing what we assume is the general area that the part would be installed. We have looked, searched, felt, followed wires, checked wiring diagrams, removed everything we can remove, inside the refrigerator liner, and in the freezer section and can find no trace to the part.
Still trying to find a tech manual for this model in hopes that it may offer clues.
12 March 2015 - 04:18 PM
Thank you for taking the time to respond, but I have the part. We are trying to determine where within the refrigerator it goes
In Topic: GE model GFSS6KKYESS frosting up in freezer
21 August 2013 - 10:58 AM
Thanks for the replies. We tested for continuity on the thermistor. would anyone know the correct ohm range we should see?
In Topic: GE Profile Refrig GSD500X-66BA Need tech sheet, and service manual if available
09 March 2012 - 08:24 PM
Correction model number is FSF26PGTABB,
