jonnyk
Member Since 10 May 2011
Offline Last Active May 22 2014 05:27 PM
Kenmore 253.60721002 refrigerator runs but won't cool
19 February 2013 - 10:32 AM
Kenmore 253.60721002 runs but won't cool
Startup amps: 6.5
Running amps: 1.1
(LRA on this compressor is 10.5 amps)
Start to Run: 28 ohms
Start to Common: 20 ohms
Run to Common: 9 ohms
Tested terminals to ground and none are grounded
Klixon overload is not open
Current relay tests ok
Compressor and discharge line feel warm to the touch but not excessively hot.
From my limited knowledge, the compressor ohm readings seem real high.  Is the compressor shot?
Kenmore 110.72802101 dryer
10 May 2011 - 07:53 PM
motor turns
ohm check shows hi limit thermostat, thermal cutoff, operating thermostat, and thermal fuse all have continuity
can see glow of ignitor for several seconds then goes out
main solenoid coil and valve coil both indicate proper resistance between terminals
flame sensor reads .5 ohms, tried to get it to open by lighting a lighter in front of the flame but the reading didn't change
according to the wiring diagram do I conclude that the flame sensor is bad which is not opening the main gas valve?
