srjacob
Member Since 13 May 2011
Offline Last Active Feb 06 2014 03:19 PM
Bosch Washer WAS20160UC drain problem
14 January 2014 - 03:41 PM
I have a strange problem with a Bosch Axxis washing machine model WAS20160UC.
The machine will work fine for a while, then stop with an F18 error.  I can't find the error in the service manual or training presentation, but I found it with a Google search.  What is happening is that when the drain pump stops pumping for about 20 seconds with water still in the tub, an F18 error occurs.  I did a manual drain, and opened up the drain pump impeller housing (there is a screw-on cap).  The impeller is clear, and the shaft turns freely.  I then put the maching on drain, and press start, and the drain solenoid clicks open, but the pump doesn't turn.  I do this a couple more times, and the impeller starts turning.  I then put everything back together, and it will run for several loads, then quits with the F18 error.  I haven't taken apart the machine to test the pump windings, but the windings on these things are reasonably heavy, and I would be supprised to have an intermittent broken winding.
I would have suspected a bad bearing in the pump, but the shaft turns fine.  When I turn the impeller, I can feel a magnetic pull ever 1/2 turn or so, so I suspect this pump has a magnetic rotor (Bosch uses the same arrangement in their dishwashers.
Anybody got a clue as to what is going on?  Is this a common problem with these machines?
Thanks in advance.
Steve
Need Bosch Dishwasher service manual SHU9912UC
16 May 2013 - 10:29 AM
Title says it all.
Need service manual for Bosch SHU9912UC dishwasher
04 February 2012 - 11:45 AM
I need a service manual for a Bosch SHU9912UC dishwasher.
The dishwasher won't completely drain. Around 1/4" to 1/2" of water remains in the dishwasher.
Thanks in advance.
Steve
Bosch SHU9912UC dishwasher doesn't complete drain
04 February 2012 - 11:43 AM
I have a Bosch SHU9912UC diswasher that doesn't complete drain. Most of the water drains, but around 1/4" to 1/2" of water still remains.
Does anyone have any idea what is wrong with this and how to fix it?
Thanks in advance.
Steve
Bosch WAS24460UC Service manual
03 November 2011 - 04:37 PM
Need a Bosch WAS24460UC Axxis+ washing machine service manual
