RivaGirl
Member Since 23 May 2011
Offline Last Active May 27 2011 01:41 AM
In Topic: Frigidaire Gallery PLRS 267ZAB6 side by side refrigerator freezing food
23 May 2011 - 07:34 PM
OK people - if the fridge is freezing, it could be the Damper.
Fridgidaire recommends seeing if that little hole going between fridge and freezer is frozen over (it's in back of meat drawer on our side by side). If there are signs of ice, it could get stuck in the fully open position (regardless of what you have it set at). If that internal auto adjuster gets stuck and lets cold air in all the time. the fridge will freeze. Their solution - a tool I use everyday. Defrost that hole area with a hairdryer.
To trouble shoot this easily before busting out the hairdryer, you can use a mirror to look for ice or use your finger to see how much cold air seeps in when the meat drawer is set to "coldest" vs "warmer."
23 May 2011 - 01:51 PM
model number on prev post PLRS 267ZAB6
