rocknronnc
Member Since 04 Jun 2011
Offline Last Active Jun 18 2013 08:13 PM
In Topic: Bosch dishwasher making draining noises
18 June 2013 - 08:15 PM
yes, i see the water draining into the garbage disposal.
In Topic: Bosch, dishwasher SHX46A05UC
05 June 2011 - 11:23 AM
i have tested the dishwasher the last two times and it has done a complete cycle. figures. i did test with a clamp on amp meter and it did not go over 1.5 amps until it went to 11.5 amps 15 minutes into the cleaning. but unlike the times before where it stop after about one minute into the cleaning and just kept in the same cycle making the same low sound, i can hear the dishwasher continue it cycles. unless this gives you any more information i will have to get back to you when the problem returns.
04 June 2011 - 11:29 AM
i am in the processing of getting a clamp on amp meter, i did a test feature on the machine by pressing the power scrub and reg wash buttons and then pressed the on button and the reg wash light lit solid and the delicate light was blinking any help?
