rocknronnc
Member Since 04 Jun 2011
Offline Last Active Jun 18 2013 08:13 PM
Bosch dishwasher making draining noises
17 June 2013 - 08:04 PM
my Bosch dishwasher SHX46A is usually pretty quiet, i just recently had to replace the drain hose because of a leak and now when it is going through its cycles i am noticing draining sounds where it empties into the garbage disposal. i did not notice these sounds before,  i connected it up just as it was with the old drain hose.
Miele gas cooktop KM 342
02 August 2011 - 07:02 PM
after turning on the burner, the ignitor will stop as usual but after 5-10 seconds the igniter will start again with the flame lit and will not stop. seems like a bad sensor but not sure where or how to service it.
Bosch, dishwasher SHX46A05UC
04 June 2011 - 09:42 AM
bosch dishwasher not completing cycles, running long have already checked the solder spot that was one indication looks good, you said that it could be the heating circuit?
