dgp
Member Since 07 Jun 2011
Offline Last Active Oct 15 2014 06:06 PM
In Topic: Spectra XL44 317B6641P001 Gas Stove - half heat - right burner out
15 October 2014 - 06:06 PM
Video of the ignition without bottom plate.
14 October 2014 - 08:27 PM
I'll take a photo and upload.  It looks like the bottom plate comes off.  There is a right and left slot and the light from the flame is definitely brighter on the left side.  I'll play around with removing the bottom and update the post.
14 October 2014 - 06:18 PM
Pardon, found the tag behind the lower heating drawer.  JGBP79WEB3WW.  Can I change the posting title?
13 October 2014 - 07:52 PM
I pulled that number off the door tag, as I found no other label.  It didn't seem like the usual WW numbers.  I'll check behind the unit and get back.
In Topic: Carrier WeatherMaker with Code 31
11 November 2013 - 11:54 AM
I checked the vents and they appeared to be clear.  I then took off the top tube to the combustion chamber and (ooops) sucked through it.  I got a throat peppering of debris.  The furnace started because the tube was off.  I then reconnected the tubing and the furnace kept running.  Did I need to cycle the power after restarting?  If not, I believe the problem was blockage in the tubing.
Thanks all,
dgp
